Hi. I have XnView 1.94.2 running on two machines. As far as I can see the settings are identical. I have a batch file to create small versions of JPEGS, which on the desktop (running Vista), puts the output files in a "small" subdirectory under the main image file directory, which is what I want.
On my laptop, running XP, the exact same script puts the files in a "small" subdirectory under My Documents, which isn't right.
Can anybody suggest what the problem might be?
Thanks
Andrew
Different Behaviour of Batch Processing
andrewj
Re: Different Behaviour of Batch Processing
I think that it was a bug in 1.94.2
andrewj
Dear Pierre,
Thanks. I've upgraded and got it working. There was also a oddity, that if I load the script from another directory, it doesn't check the tick box next to the script name. Once it's run once, and re-set the default script directory, it's fine.
Andrew
Andrew
