IPTC indicator on thumbnail view not clearing
ronkrz
Post by ronkrz »
Using Windows XP SP2. In either 1.96.0 or 1.96.1, for a jpg image, after entering IPTC caption, IPTC 'indicator' on thumbnail properly appears. But if it is cleared, the indicator remains. Irfanview does show it cleared, but thumbnail view in XNVIEW still shows indicator, but detail view tab does properly not show for IPTC. Tried refresh too. :?
Tried 'clear all' in Edit IPTC, then XMP indicator comes on, and XMP tab displays following:
<?xpacket begin="" id="W5M0MpCehiHzreSzNTczkc9d"?> <x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.1.1"> <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"> <rdf:Description rdf:about="" xmlns:xap="http://ns.adobe.com/xap/1.0/" xmlns:exif="http://ns.adobe.com/exif/1.0/" xmlns:tiff="http://ns.adobe.com/tiff/1.0/" xap:CreatorTool="Picasa 3.0" exif:ExifVersion="0210" exif:ImageUniqueID="da0114eba176e0f2bb70dbf66512cb79" exif:NativeDigest="36864,40960,40961,37121,37122,40962,40963,37510,40964,36867,36868,33434,33437,34850,34852,34855,34856,37377,37378,37379,37380,37381,37382,37383,37384,37385,37386,37396,41483,41484,41486,41487,41488,41492,41493,41495,41728,41729,41730,41985,41986,41987,41988,41989,41990,41991,41992,41993,41994,41995,41996,42016,0,2,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,20,22,23,24,25,26,27,28,30;7404536A135C1DDF15D9B3493C5A9692" tiff:NativeDigest="256,257,258,259,262,274,277,284,530,531,282,283,296,301,318,319,529,532,306,270,271,272,305,315,33432;7B73D959242A3494AACA6DFBD51B6A28"/> </rdf:RDF> </x:xmpmeta> <?xpacket end="w"?>
Any ideas on this? Has the image been corrupted now? :?:
Ron
Re: IPTC indicator on thumbnail view not clearing
ronkrz wrote:Using Windows XP SP2. In either 1.96.0 or 1.96.1, for a jpg image, after entering IPTC caption, IPTC 'indicator' on thumbnail properly appears. But if it is cleared, the indicator remains. Irfanview does show it cleared, but thumbnail view in XNVIEW still shows indicator, but detail view tab does properly not show for IPTC. Tried refresh too. :?
Do you 'clean' iptc metadata? or simply clear all fields?
ronkrz
Post by ronkrz »
I must have used 'clear all' in edit IPTC. I thought I tried 'clean metadata', but maybe didn't check everything there, because that worked! The thumbnail indicators cleared up. :D
Thank you!
