I have to create an add-on for XnView to edit IPTC for a jpg.
The interface should be simple and have only required fields.
The problem is that I found no documentation or tutorial that explain how to create an add-on.
Thank you to give me a link or a starting point.
Nexio
[Add-on]Personalized IPTC editor
Alexis
Re: [Add-on]Personalized IPTC editor
Up?
Same question... + many other ones that may be answered by a documentation/tutorial.
Thanks!
Thanks!
Do you have downloaded the Addon sample source?Alexis wrote:Up?
