My digicams from Monica Minolta use to write jpg files with the extension "jpe", in case of jpg files with an embedded color profile. Unfortunatelly XnView Pocket does not support jpg files with that extension. It's just a problem with the not supported extension. Tests showed me, that XnView can handle those files, if I rename the extension to jpg.
Dat Ei
jpe support
Re: jpe support
Ok, i'll add .jpe extensionDat Ei wrote:My digicams from Monica Minolta use to write jpg files with the extension "jpe", in case of jpg files with an embedded color profile. Unfortunatelly XnView Pocket does not support jpg files with that extension. It's just a problem with the not supported extension. Tests showed me, that XnView can handle those files, if I rename the extension to jpg.
Dat Ei
Hey Pierre,
did you get my example? May I ask you if and when you will release the next xnview pocket version, and if it will have a jpe support? Any thoughts about this feature?
Dat Ei
Dat Ei
Yes, i have it, and i'll check your request.Dat Ei wrote:did you get my example? May I ask you if and when you will release the next xnview pocket version, and if it will have a jpe support? Any thoughts about this feature?
Dat Ei
Dat Ei
