I have a issue with the 'Send pictures by e-mail' function. It always tries to open the Windows Mail program in Vista, instead of Thunderbird, which is set as my default mail application. Sending e-mail from other applications (e.g. Opera) works fine. Do you have an idea what could be the problem?
Best regards,
Peter
'Send by E-mail' opens Windows Mail instead of default mail
Re: 'Send by E-mail' opens Windows Mail instead of default mail
Try :
1° Outlook ---> default
2° Thunderbird ---> default
I dont' speak english...
It was a problem of Thunderbird (version 2.0.22) - it was enough to reinstall it and it works now.
Reference to http://newsgroup.xnview.com/viewtopic.php?f=36&t=17980 where an update of XnView helps.
