Is there an XP skin?
erdinc
Post by erdinc »
I'm trying to make xnview look like any folder in XP. Are there any button sets that I can use with version 1.96.2.
The reason why I have found out about xnview is the problems with video thumbnails in XP. I have folders inside other folders in my video folder. So I'm trying to make it feel like I'm still opening my videos folder.
When you open any folder in XP, go to view/explorer bar/folders and it will make it look like windows explorer adding the ability to browse.
For pictures I was using faststone image viewer but since I discovered xnview I started to switch towards it for picture browsing as well. It is better than faststone image viewer sine xnview lets me change the layout or panels while the other doesn't. But faststone image viewer comes with build-in skins and xp skin is included. It is a shame that xnview doesn't have build in skins.
Erdinç
oosterhagen
Re: Is there an XP skin?
Post by oosterhagen »
I've uploaded a skin. Have a look at the Customizations section.
