Remember Window Position & Close Image by Double Click?
gordho
Post by gordho »
Just discoved XnView 1.74 and it is great.
One problem I do have with XnView is when I double click on an image from the thumbnail browser it opens the image centered on the screen. If I move the window to the far left of the screen then close it to go back to the browser and then open the same image or another image it puts it back at the center of the screen. I have "Fit window to image," "Force XnView to fit image," and "Remeber last window position/size" set. Is this behavior by design? Is it possible to change this to remember where the last image was viewed? "Remeber last window position/size" only seems to effect the browser and not the viewed image.
When I view an image and then double right click to close, the browser window is resized to the the same size as the last viewed image. If I close the image by clicking the close button then the browser window goes back to the proper size. I am right handed and have Windows XP set to switch primary and secondary buttons.
Any thoughts of adding an Auto-advance feature similar to the one in Acdsee?
Re: Remember Window Position & Close Image by Double Cli
gordho wrote:Just discoved XnView 1.74 and it is great.
I've added an option to use different position/size for view & browser in next 1.75
gordho
Post by gordho »
awesome, thanks!!
