Hi there,
I have to work on upgrading our code from using the libgfl 2.5 to using libgfl 3.11.
The code, obviously, doesn't run correctly. I get a lot of errors and it crashes.
Is there a place to find some updated documentation on the SDK. Maybe something that explains the workflow and HOW to use it rather than just say that function x does y? I'd like to understand the code before I change it, to make sure that the changes are the optimum changes.
Thanks in advance for any help.
Maxi
Documentation for newbie
iycgtptyarvg
Re: Documentation for newbie
Just look in the directories of the GflSdk. There are examples there.
If you need some assistance you can search or ask for details in GFL forum.
Dom
