Webshots wb1
soontogotoo
Webshots wb1
I am feeling ignorant or forgetful -- webshots wb1 format. I downloaded the newest version of xnview [redoing my computer like a fool] and am unable to convert a wb1 format. I believe I have activated and downloaded all of the available formats / plugins -- I don't find the format listed anywhere and the system doesn't recognize the format. Anyone out there ?? Thanks
Re: Webshots wb1
• WB1 is supported at reading only like you can check HERE…
Paula
Re: Webshots wb1
Hello, I'm a newbe here...Clo wrote:soontogotoo
Hello ! Welcome aboard !
Kind regards,
I alway's used XNVIEW to see my webshots images but since I updated to the latest version I do not see them anymore and when I try to open them I get an error message saying thet it is not possible to read them. I installed the full version so I do not understand what is happening because as I found on the net it should be no problem to see them displayed in XNVIEW
Many thanks for a little help and have a nice day
Paula
Re: Webshots wb1
• You must have the option :
Options (F12) >> General [×] Display all image files types ticked !
• Further, whether that doesn't work either, you could add the WB1 extension in the include field of the box :
Options >> File list, please see HERE
Paula
Re: Webshots wb1
Hi Claude,Clo wrote:Paula
Hi Paula ! Welcome aboard !
Kind regards,
Many thanks for your quick reply but I have one more question for you. Do I just have type wb1 or do I have to type something more there?
Thnx again
Re: Webshots wb1
• No, only the extension¦s you need to get displayed, like it's explained in our online Manual page…
- Note : The indications “Include” and “Exclude” are NOT on the real dialogue, they are still missing despite N… requests…
Paula
Re: Webshots wb1
Okido thanks Claude - I will enter WB1 exe - (as typed here without the " " from in the example) and see what happens ok?Clo wrote:Paula
Again…
KR
- Forum Librarian
Paula
Re: Webshots wb1
Thank you for this post but... if it was that easy - I would not have asked how to do it
Anyhow I added the extention as mentionned above but it still not worked for me - but as I saw the the program is also presented in a ZIP file on the net and then you do not have to install anything, I transferred that programfile from my other laptop and did an upgrade with an install from 1.97 in the same directory and yet it works again for me too.
This might be the solution for other people too
