How to open Pagis xif files
tenderfoot
Post by tenderfoot »
On the XnView website it suggests that XnView can read xif files. I've used Pagis Pro for scanning documents for several years and have accumulated zillions of documents in the Pagis xif format. Pagis, however, is not compatible with Vista and I need a reader for these files.
Is there an add-on for XnView or am I missing something? When I try to open a xif file with XnView I get an error message "TIFF: Bad data compression algorithm!"
I know xif is a modified TIFF, but it's a great format and text/graphics are compressed better (in 4 distinct layers), so one does not have to sacrifice either.
How can I get XnView to open xif files?
Tenderfoot (a newbie to this forum)
Re: How to open Pagis xif files
eL_PuSHeR
Post by eL_PuSHeR »
I have found this page by using Google. I don't know whether it will work or not because I don't have any .xif files.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Only some xif files can be loaded...
eL_PuSHeR wrote:I have found this page by using Google.
Thank you for the hint, eL_PuSHeR.
Direct link: The Pagis Viewer and XIFF Plug-In » viewer.exe
