delete image while in slide show
xahlee
Post by xahlee »
is it possible to delete a image while in slide show?
I have a fold, containing many sub folders. The folder contains 30k image files. I want to view them randomly (either by slide show or by random display in normal mode), and be able to delete the current file.
I searched the forum. Saw one message posted by author back in 2006 asking users whether this should be implemented. The feed back seems to be positive, but i can't find any info about whether this has been implemented. Thanks a lot.
Dreamer
Re: delete image while in slide show
Post by Dreamer »
It is possible, but only in Quick Slide Show. To start (and stop) it press Pause/Break key, to configure right click in fullscreen mode and select "Configure Quick Slide Show...". In Quick Slide Show some features are missing (transition effects, "play sound").
Dreamer
xahlee
Post by xahlee »
Dreamer wrote:It is possible, but only in Quick Slide Show. To start (and stop) it press Pause/Break key, to configure right click in fullscreen mode and select "Configure Quick Slide Show...". In Quick Slide Show some features are missing (transition effects, "play sound").
Hi, how do i start the Quick Slide Show? I looked in all the menus and icons... don't seem to find it. Pressing Pause key doesn't seem to do anything. Thanks.
Dreamer
Post by Dreamer »
In fullscreen first right click > "Configure Quick Slide Show..." - set Delay in ms, then right click again > "Quick Slide Show" (or just Pause/Break) and wait a bit.
Dreamer
xahlee
Post by xahlee »
Dreamer wrote:In fullscreen first right click > "Configure Quick Slide Show..." - set Delay in ms, then right click again > "Quick Slide Show" (or just Pause/Break) and wait a bit.
Thanks! Finally i found Quick Slide Show. However, right click simply switch to next picture. But eventually i found the Configure Quick Slide Show in Options, under View (as opposed to under a leaf node).
Thanks.
Dreamer
Post by Dreamer »
xahlee wrote:...right click simply switch to next picture. ...
Then you have to disable this feature "navigation with mouse" or similar first...
Dreamer
