Cropping Improvements
willgoss
Post by willgoss »
I really like using XN for simple editing and for its support for plugins - 80 percent of my work can now be done in XN....some areas could better support the editing..
Cropping.....The Grid Settings could be improved by supporting percentage.....even better add Thirds, Golden Ratio and Diagonals......but even better would be to add the grid settings to the selection, this is where they are best used while cropping......also an easier way to set the selections especially while cropping....
Thanks for your consideration......Will
