Crash while opening JPEG file
DarkCat
Post by DarkCat »
http://www.kinopoisk.ru/images/poster/or_871062.jpg (4040x5747 px, 2.1 MB)
I save this picture in my hard drive, then open it and the program crash. (version 1.96.2)
Application popup:
XnView: xnview.exe - Application Error
The instruction at "0x005c72e8" referenced memory at "0x00e74000". The memory could not be "read".
Click on OK to terminate the program
Click on CANCEL to debug the program
This is my problem?
In other picture viewers it's ok...
Re: Crash while opening JPEG file
:arrow: DarkCat
:) Hello ! Welcome aboard !
• I downloaded then displayed that image in XnView 1.96.2 without any problem…
or_871062.jpg 2 165 640 (Bytes) 26/07/2009 05:40 -a--
SHA1 Checksum :
• In “View” mode (from Total Commander >> Button on the tool-bar).
:mrgreen: Kind regards
Win XP-Pro SP1 (FR)
JPEGsnoop wrote:
*** Decoding SCAN Data ***
  OFFSET: 0x00003DA3
  Scan Decode Mode: Full IDCT (AC + DC)
  Scan Data encountered marker   0xFFD9 @ 0x00210B86.0
*** NOTE: YCC Clipped. MCU=( 179,  38) YCC=(   -1,  128,  128) Y Underflow @ Offset 0x00210B85.7
*** NOTE: YCC Clipped. MCU=( 182,  38) YCC=(   -1,  128,  128) Y Underflow @ Offset 0x00210B85.7
*** NOTE: YCC Clipped. MCU=( 182,  38) YCC=(   -3,  128,  128) Y Underflow @ Offset 0x00210B85.7
*** NOTE: YCC Clipped. MCU=( 182,  38) YCC=(   -6,  128,  128) Y Underflow @ Offset 0x00210B85.7
    Only reported first 10 instances of this message...
  Compression stats:
    Compression Ratio: 32.40:1
    Bits per pixel:     0.74:1
eL_PuSHeR
Post by eL_PuSHeR »
It seems Irfanview displays it without problems.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
:arrow: eL_PuSHeR
:) Hello !
• It works OK here too in “Imagine” and “Universal Viewer”, still from Total Commander…
… and like I said above, no problem in XnView 1.96.2. The option Fit Image to window (large only) is ON.
:mrgreen: KR
With last version?
