Adjust Improvments
willgoss
Adjust Improvments
Post by willgoss »
The Adjust menu is great....I would like, in the main section, Brightness, Gamma, Contrast to add the Saturation from the optional menu, as these are the 4 most common settings used, then the addition of reset or better yet View Original....finally an ability to adjust "Highlights-Mid-Shadows" all within that Menu set.....
This then, in one Menu let the adjustments to be set....this makes XnView into a real Photo fix/repair program......It also gives us a superior B&W conversion support.....
Will Goss
