Category get lost by batch rename
Felix12
Categiries get lost if you batch rename your files even in versin 1.96.2. Does anybody know how you can handy this.
Re: Category get lost by batch rename
Right, an issueFelix12 wrote:Categiries get lost if you batch rename your files even in versin 1.96.2. Does anybody know how you can handy this.
Felix12
Thanks for the quick reply. Is there any way to batch rename in the database. If so where will I find the category database.
Nevertheless a great programm! Thanks for it.
- Forum Librarian
Felix12 wrote:Is there any way to batch rename in the database. If so where will I find the category database.
