Can anyone advise me if I am hitting a limit or what the problem might be please.
I am looking to combine 4 slices of a large image back together,
in my first attempt all worked well, each TIF file was 5132x10264 Pixels, the final file being 20528x10264, and as I say this was created no problem,
I then attempted a set of images that were 5392x10784, after selecting the files, I hit Create but the dialog window just disappeared, no error messages, main window continued OK.
After playing around a little it seems I can combine 3 images, no problems, but not 4 images.
On a different set of files of size 5181x10362, the same problem occurs.
It would seem that there is some limit relating to the width of the final image when it exceeds 20528 pixels - or have I missed something ??
Using versions 1.96.1 or using 1.96.2 under Windows XP Pro SP3 with 3G memory switch on
Geoff
File size limits in Panorama ?
g8dhe
Geoff G8DHE
Spherical Visions
Spherical Visions
g8dhe
Re: File size limits in Panorama ?
OK, is the disappearing window normal behaviour then for this situation ? I've only been using the package for a week or two, I assumed I had missed some parameter out.
Geoff G8DHE
Spherical Visions
Spherical Visions
Yes, no message. I'll add oneg8dhe wrote:OK, is the disappearing window normal behaviour then for this situation ? I've only been using the package for a week or two, I assumed I had missed some parameter out.
g8dhe
Many thanks Pierre its nice to see such a rapid response.
Is there any similar facility in Nconvert ? I couldn't see anything looking at the command structure however.
Geoff G8DHE
Spherical Visions
Spherical Visions
Not in Nconvertg8dhe wrote:Is there any similar facility in Nconvert ? I couldn't see anything looking at the command structure however.
