i use xnview for a while and it's the first time i have this problem:
when i display black & white TIFF, the thumbnail (and also the normal size) image on xnview i just see some noises...
and the problem appears just with b&w tiff, there is no pb with colour tiff...
is it a problem from xnview or a problem on my computer?
does someone know a solution for this problem?
thanks,
laurent
Pb with b&w TIFF
Re: Pb with b&w TIFF
Do you have enable option/View/High zoom>reduce?
lorseau
yes this checkbox is enable
lorseau
(btw i uninstalled everything, so now it's a brand new version)
could you send me the tiff?lorseau wrote:yes this checkbox is enable
lorseau
yes
could you give me an email to send one of these tiff?
