problem with pct files
Selmi
Post by Selmi »
i had a lot of pct files (created by conversion from .rsrc resources from one palmos project to .rcp). unfortunately there are some which can't be opened by xnview. is there any known issue with pct format support or did i find something new? i can send example files if needed
for more info selmi<_at>centrum<_dot>sk
Re: problem with pct files
Selmi wrote:i had a lot of pct files (created by conversion from .rsrc resources from one palmos project to .rcp). unfortunately there are some which can't be opened by xnview. is there any known issue with pct format support or did i found something new? i can send example filed if needed
Could you send me some samples, please?
