XV exits on "Capture Screen".
Jabbson
Post by Jabbson »
When i capture screen using delay method everything is just fine, but the hot key capturing makes XnView exit.
marsh
Re: XV exits on "Capture Screen".
Post by marsh »
Jabbson wrote:When i capture screen using delay method everything is just fine, but the hot key capturing makes XnView exit.
Which key combination? Only one of them?
