Dialog windows break Win+D functionality (SOLVED)
Dstruct
Post by Dstruct »
XnView 1.96.2
-> open a dialog window ("About" for example)
-> try to go to the desktop via Win+D (global Windows shortcut)
=> Doesn't work :(
Works fine in other applications.
EDIT: Seems to be caused by a Total Commander background transfer window.
SOLVED
