Broken alpha
Enmoku
Broken alpha
Post by Enmoku »
Here's an image (another game screenshot) that displays rather strangely in XnView:
And here's what the image looks like if I remove alpha channel.
(Unfortunately the buggy(?) file is about 7MB in size and I don't have a host that would accept it (photobucket converts it to jpg automatically.)
Zooming close enough (150% or more) also fixes the issue. Converting the file to PNG with ShellEx creates a mostly white image that's completely broken (zooming doesn't help anymore and there's no alpha channel to remove). Converting to other formats (that I tested) behaves in similar fashion to the original BMP while conversion to JPG "fixes" it.
If the grayness is correct, then zooming close enough and the gray disappearing is the buggy part. Also, the PNG losing the alpha channel (if there ever was one) is another issue.
Enmoku
Re: Broken alpha
Post by Enmoku »
Apparently the buggyness was kept on image resize, uploaded it here: http://www.mediafire.com/?imninnnyz2o
marsh
Re: Broken alpha
Post by marsh »
Does this work with shellext (I don't have it installed)?
Options>General>Operations>[x]Ignore Alpha Channel
(effects conversion of transparent image)
Re: Broken alpha
Enmoku wrote: And here's what the image looks like if I remove alpha channel.
Are you sure that alpha is correct?
Enmoku
Re: Broken alpha
Post by Enmoku »
That's what the file had. As I said, it was game screenshot (one that the game itself produced), so only thing I know of correctness is how it is displayed and how it should (I know what the game looks like).
Enmoku
Re: Broken alpha
Post by Enmoku »
marsh wrote:Does this work with shellext (I don't have it installed)?
No such option, and that wouldn't explain why some formats preserve the alpha channel and others (PNG) don't, unless it was a format specific setting, but PNG options didn't have anything related to alpha/transparency.
marsh
Re: Broken alpha
Post by marsh »
It exists in newest version. With a completely different bmp sample, the following option is ideal for me:
Options>General>Read/Write>Read>PNG>[x]Compose image with transparency.
From topic FAQ index:
Enmoku
Re: Broken alpha
Post by Enmoku »
marsh wrote:Options>General>Read/Write>Read>PNG>[x]Compose image with transparency.
This option is not present in ShellEx.
And regardless of that, the conversion is not the issue, but the buggy display.
Re: Broken alpha
Enmoku wrote:And regardless of that, the conversion is not the issue, but the buggy display.
But the display is not buggy, it's the file
Re: Broken alpha
Enmoku
Re: Broken alpha
Post by Enmoku »
If the display isn't buggy, then why does the greyness disappear when zoomed close enough? If it was only the file, the buggyness should be present regardless of zoom level.
Re: Broken alpha
Perhaps due to smooth resize. Please resend the file?
Enmoku
Re: Broken alpha
Post by Enmoku »
Disabling HQ zoom did make the quirky alpha remain.
Here's a reduced size version of it that exhibits the bug with HQ zoom on as requested, though: http://www.mediafire.com/?zmq2u0yeyql (~600kB)
Re: Broken alpha
Enmoku wrote:Disabling HQ zoom did make the quirky alpha remain.
I don't see any problem, i have no grey, you can take a look at the alpha channel (M key)
