Canvas resize "as delta" in batch mode
Peter2
Post by Peter2 »
I tried "canvas resize", width "-157", height "0", "use above values as size delta".
The saved XBS is this:
canvas( 0 #-157 #0 6 255 255 255 0 )
settings( 3 0 1 0 1 0 )
output( tiff 2 6 0 )
Problem: It resize twice 157 pixel. Same happend with "-300" - it resize with 2x300 = 600 dpi"
Edit:
This happens only with the option "width". The option "height" resizes correctly.
Peter
marsh
Re: Canvas resize "as delta" in batch mode
Post by marsh »
Confirmed. Both bottom-left and bottom-right double the H delta.
Peter2
Post by Peter2 »
The height or the width? Or is is dependent from the base-point?
Peter
marsh
Post by marsh »
Peter2 wrote:The height or the width? Or is is dependent from the base-point?
Peter
I tested width 100, height 0 delta at each base-point. Starting from the 2 lower corners, the opposide side had increased canvas of 200 pixels on an edge. I didn't use the script functions.
---Edit---
The w-0, h-100 combinations all work.
