Access Denied in gflBitblt
reggi
Post by reggi »
Hi!
I have always AccessDenied in procedure:
procedure BlurFragment(X, Y, W, H, blur: integer; templImage: PGFL_BITMAP; bgColorGFL: TGFL_COLOR);
var
   cropRect: TGFL_RECT;
   fragment: PGFL_BITMAP;
begin
     rC1 := repeatCount;
    try
        cropRect1.x:=X;
        cropRect1.y:=Y;
        cropRect1.w:=W;
        cropRect1.h:=H;
        fragment := gflAllockBitmap(gfl_bmp.BType,
                                  W-X,
                                  H-Y,
                                  gfl_bmp.LinePadding,
                                  @bgColorGFL);
        gflBitblt(templImage, @cropRect, @fragment, 0, 0);
        gflGaussianBlur(fragment, nil, blurSize);
        cropRect.x:=0;
        cropRect.y:=0;
        cropRect.w:=fragment.Width;
        cropRect.h:=fragment.Height;
        gflBitblt(fragment, @cropRect, @templImage, X, Y); // HERE IS ACCESS DENIED...
    finally
        FreeAndNil(cropRect);
        gflFreeBitmap(fragment);
    end;
end;
I've no idea what's wrong :/ In my opinion the code is correct but... why there is AV? :/
dominique
Re: Access Denied in gflBitblt
Post by dominique »
Here is something wrong, isn't it?
                                  W-X,
                                  H-Y,
                                  @bgColorGFL);
Should be
                                  W,
                                  H,
                                  @bgColorGFL);
to match with the cropRect ?
Dom
reggi
Post by reggi »
I KNOW!!
The problem is in the libgfl.pas file.
There is:
function gflBitblt(src: PGFL_BITMAP; rect: PGFL_RECT;
dst: PPGFL_BITMAP; x_dest, y_dest: GFL_INT32): GFL_ERROR; stdcall;
Should be:
dst: PGFL_BITMAP; x_dest, y_dest: GFL_INT32): GFL_ERROR; stdcall;
Ok, i'll change it
reggi
Post by reggi »
Will You change in libgfl.pas or in dll?
I think I can verify entire libgfl.pas because there are more errors, and then i'll send you it.
reggi wrote:Will You change in libgfl.pas or in dll?
I'll change the .pas, the dll is correct with the C header
reggi
Post by reggi »
OK.
Correct too error in line 265. There is:
	ExtrasInfo: Pointer
Should be with semicolon:
    ExtrasInfo: Pointer;
madiazg
Post by madiazg »
The errors I found in "libgfl.pas" are:
//function gflSetColorAt(var dst: PGFL_BITMAP; x, y: GFL_INT32; var color: TGFL_COLOR): GFL_ERROR; stdcall; [ERROR]
   function gflGetColorAt(const src: PGFL_BITMAP; x, y: GFL_INT32; var color: TGFL_COLOR): GFL_ERROR; stdcall;
//ExtrasInfo: Pointer [ERROR]
//GFL_EXIF_MAIN_IFD             = $0001; [ERROR]
//GFL_EXIF_IFD_0                   = $0002; [ERROR]
   GFL_EXIF_MAIN_IFD             = $0002;
   GFL_EXIF_IFD_0                   = $0001;
and include:
procedure gflBitmapSetEXIFValueRationalArray2(exif: PGFL_EXIF_DATAEX; ifd, tag: GFL_UINT16; const pq: PGFL_UINT32; count: GFL_INT32); stdcall;
The latter gives me an error in the EXIF data from Nikon cameras:
http://newsgroup.xnview.com/viewtopic.php?f=4&t=17966
Miguel Angel
