Wrong size while open PS and EPS files using GflAx - ASP
Post by Guest »
Hi, i am trying to manage my personal image files, which there are many formats; eps, ps, tiff....
So far there is little problem in opening the other formats but in PS and EPS
I cannot get the full image. As the GflAx open the files based on the definite width and length while opening them.
What I had done,
I had load the original image into the "server" using aspupload
then I resize it into the original size as jpeg, half size (mid) and thumbnail(quarter).
I had wanted to use the width and height to open the image in full but
this dimension used the one I had defined.
If the epswidth and epsheight set is too large the image is loaded but become very small. If they are set too small, then the image is not
fully load.
I therefore used the size (MB) to determine the size but it does not give an acurate one.
Below is my code.
Thank you.
	UpFile.SaveAsVirtual strOriginalFile	'save the original file into my
							      'server using aspupload
	'treating format GflAx cannot open
	if strFileExt =  ".ind" then
		strFileName = "indd.tif"
	else
		if strFileExt =  ".ai" then
			strFileName = "ai.tif"
		else
			if left(strFileExt,3) = ".fh" then
				strFileName = "fh.tif"
			end if
		end if
	end if
	'GflAx setup and the server folder
																	PathO		= Server.MapPath("/ImgOriginal")
		PathA		= Server.MapPath("/ImgActual")
		PathM		= Server.MapPath("/ImgMid")
		PathT		= Server.MapPath("/ImgThumb")
		strOriginalFile	=	PathO & "/" & "Original_" & strFileName
		strMidFile	= PathM & "/" & "Mid_" & ctrlFileID
		strThumbFile = PathT & "/" & "Thumb_" & ctrlFileID
		strActualFile  = PathA & "/" & "Actual_" & ctrlFileID
	'/GflAx setup
	'load the file to check the dpi n size for eps or ps file
		if strFileExt = ".eps" or strFileExt = ".ps" then
			Set GflAxObjChk	= server.createobject("GflAx.GflAx")
																		GflAxObjChk.epsWidth	=3000
				GflAxObjChk.epsHeight	=3000
				GflAxObjChk.epsDpi	= 60
				GflAxObjChk.EnableLZW	= True
				GflAxObjChk.LoadBitmap strOriginalFile
				strPixLoadWidth	= GflAxObjChk.Width
				strPixLoadHeight	= GflAxObjChk.Height
				strPixXdpi	= GflAxObjChk.Xdpi
				strPixYdpi	= GflAxObjChk.Ydpi
				strPixByte	= GflAxObjChk.OriginalSize
				' the width and height does not help to extract the
				'actual image dimension
			Set GflAxObjChk	= nothing
		end if
		'/load the file to check the dpi n size for eps or ps file
		'Actual GflAxObj loading reSize and Save Image
			Set GflAxObj	= server.createobject("GflAx.GflAx")
			with GflAxObj
			if strPixByte < 1000000  and strFileExt = ".eps" then
				.epsWidth	= 500
				.epsHeight	= 500
				.epsDpi		= 60
			else
			if strPixByte < 10000000 and strFileExt = ".eps" then
				.epsWidth	= 1500
				.epsHeight	= 1500
				.epsDpi		= 60
			else
			if strPixByte > 100000000 and strFileExt = ".eps" then
				.epsWidth	= 3000
				.epsHeight	= 3000
				.epsDpi		= 60
			else															if strPixByte < 1000000  and strFileExt = ".ps" then						.epsWidth	= 1500
				.epsHeight	= 1500
				.epsDpi		= 60
			else															if strPixByte < 10000000 and strFileExt = ".ps" then						.epsWidth	= 2500
				.epsHeight	= 2500
				.epsDpi		= 60
			else															if strPixByte > 100000000 and strFileExt = ".eps" then						.epsWidth	= 3000
				.epsHeight	= 3000
				.epsDpi		= 60
			end if
		end if
		end if
		end if
		end if
		end if
		end if
																	.EnableLZW	= True
		strImgWidth	= .Width
		strImgHeight	= .Height
		'strImgByte	= .OriginalSize
if strFileExt =  ".ind" or strFileExt =  ".ai" or left(strFileExt,3) = ".fh" then
	strMImgWidth	= strImgWidth
	strMImgHeight	= strImgHeight
else
strMImgWidth	= strImgWidth/2
strMImgHeight	= strImgHeight/2
end if
	strTImgWidth	= strImgWidth
	strTImgHeight	= strImgHeight
else
	if strImgByte < 1000000 then
		strTImgWidth	= strImgWidth/2
		strTImgHeight	= strImgHeight/2
	else
		strTImgWidth	= strImgWidth/4
		strTImgHeight	= strImgHeight/4
	end if
end if
.SaveFormat = 1
.SaveFormatName = "jpeg"
.SaveJPEGProgressive = True
.SaveJPEGQuality = 70
.SaveBitmap(strActualFile)
.Resize strMImgWidth, strMImgHeight
.SaveFormat = 1
.SaveBitmap(strMidFile)
.SaveFormat = 1
.SaveBitmap(strThumbFile)
end with
set GFlAxObj	= nothing
'/Actual GflAxObj loading reSize and Save Image
[/code]
Re: Wrong size while open PS and EPS files using GflAx - ASP
Guest wrote:Hi, i am trying to manage my personal image files, which there are many formats; eps, ps, tiff....
What I had done,
fully load.
Is it possible to have a link to your EPS/PS file?
