File listing to CSV - wrong separator
Peter2
Post by Peter2 »
I tried to export a filelist to CSV and got a comma , as separator. My Excel (2003, german) needs and saves "semicolon ;" as separator.
Is this a bug or is it dependent from language and country settings?
Peter
Re: File listing to CSV - wrong separator
And CSV can't be imported if you select the good separator in Excel?
Peter2
Post by Peter2 »
Of source - selecting a separator does everything.
BUT: A doubleclick on a CSV (with ",") opens it with "all in one column"; a doubleclick on a semicolon-CSV opens it perfectly.
Peter
; is the default separator?
Peter2
Post by Peter2 »
xnview wrote:; is the default separator?
Yes - in my configuration. "," is very often used as decimal point (Germany, Austria), and therefore it can not be a separator (IMHO).
"Pi: 3,1415927"
Peter
