it would be very useful, if there is an undo button in viewer mode for renaming, copying, deleting...
It should at least undo 10 steps!
Great tool!
regards,
Stefan
undo in viewer mode
surfacecleanerz
- Contact:
Re: undo in viewer mode
• It was implemented in the 1.92 version ! Before, we had a single level only…[View]
UndoCount=n…
“n…” is the count of changes which can be undone from the button of the tool-bar (default : 5)
… but for “Delete” the only Undo is the Recycle Bin (if you have set it in the Options…)
surfacecleanerz
- Contact:
really? cool! And where is the button for it in the folder view mode? In fullscrenn mode there it is!
regards,
Stefan
regards,
Stefan
