Hotkeyp for vista 64, cant run spy.exe
All non-XnView related: softwares, formats, imaging, photography...
And 1
Post by And 1 »
I moved from XP pro, to vista 64. Sadly none of my shortcuts work anymore. So I figure I can just run the spy.exe to get the new explorer ID #'s, or something.
Any ideas? THANKS!
Dreamer
Re: Hotkeyp for vista 64, cant run spy.exe
Post by Dreamer »
Which shortcuts don't work exactly, for example?
I don't have any problem with HotkeyP on Windows XP and Vista 32 bit.
Perhaps spy.exe needs admin rights, try to run hotkeyp.exe and spy.exe as administrator.
Dreamer
And 1
Post by And 1 »
The commands that no longer work are the "sort by" and "view as..." keys. I have 15 different ones and the rest work.
I tried to run spy as admin, but it doesnt work.
"C:\WINDOWS\explorer.exe" is the working directory in vista 64. I've also tried to type in the other syswow64 directory. I've ran hotkeyp as admin too.
Dreamer
Post by Dreamer »
Do you mean the multimedia keys - or "sort by" and "view as..." in explorer window??
You could try to contact the author of HotkeyP, but it looks he's too busy. :(
Dreamer
