Is there a way, when viewing a multi-page TIFF file, to press the Save-as button, choose save as type PDF, and get all the pages?
I am using version 1.96.2 for Windows.
Multi-page TIFF files, Save as PDF
Re: Multi-page TIFF files, Save as PDF
• No, you can't as one go, only the first page can be saved (that stands for all multi-page formats).
• You ought extract all the pages from the TIFF into any empty temp. folder, then build the PDF from
Tools >> Create Multi-page file…
Drahken
Open xnview, click tools->multipage->create multipage. Select your tiff file, then make sure to check the "include all pages from multipage files" box, then choose tiff or pdf or lurawave or whatever format you want.
askural
The tools and multipage did the trick.
Thank you and thanks Xnview
ASKural
ASKural
pbenner
I could not find the Tools->Multipage option in xnviewMP/Mac but I did manage to do it using the Tools->Batch Convert... option. A little more work but got the job done: 2 page TIFF converted to 2 page PDF. BTW, thinking I could just use the print dialog and save to PDF from there didn't work. XnviewMP unexpectedly quit every time I invoked the print command while viewing a 2 page TIFF.
Drahken
XnviewMP is a significantly different program from normal xnview. It doesn't seem to have any way to create a multipage image.pbenner wrote:I could not find the Tools->Multipage option in xnviewMP/Mac .....
yes not yet implementedDrahken wrote:XnviewMP is a significantly different program from normal xnview. It doesn't seem to have any way to create a multipage image.pbenner wrote:I could not find the Tools->Multipage option in xnviewMP/Mac .....
