XnView can't open a few photos at once
DJ J
Post by DJ J »
I'm using XnView v. 1.96.2. I've set this application as my default jpeg viewer. When I'm trying to open a few photos at once (select a few files from Win XP hard drive folder->than click right mouse button->than command "Open"), Win XP asks me "where these files should be moved" and after that XnView open all my selected files.
How can I fix this problem?
Regards! :o
orion
Re: XnView can't open a few photos at once
Post by orion »
XnView 1.96.2
Options: General -> "Only one instance" enabled, View -> "Only one window view opened" disabled
Unconfirmed. XnView opens all selected files in separate tabs (or separate processes if "one instance" option is disabled). No any messages appears.
DJ J
Post by DJ J »
Yes, that's right - no any messages appears. But in my case after rebooting Windows XnView opens photos in separate processes (not in separate tabs) in spite of 'General -> "Only one instance"' selecting and 'View -> "Only one window view opened"' unselecting.
Please, check this behaviour after rebooting Windows.Greetings! 8)
