Add Text: Align to mouse position
Note: This suggestions has been made by XnView user G.S.
When adding text, it's good to have the alignment. It might be a good idea to change the insert position depending on the alignment:
- When using left aligment, it would be good if the mouse indicated the left position.
- When using center alignment, it would be good if the mouse indicated the center position
- When using right alignment, the mouse should indicate the right position.
This way, text could be inserted more precisely. To make the difference clear, the cursor shape might change, too.
