When viewing a multiple page TIFF, for example, doing Save As warns you that only the currently viewed page will be saved. I wish to prevail upon the kind and talented people who wrote this wonderful program that multi-page Save As should be added in a future release.
I frequently use the XnView to view faxes saved as TIF files, and I need to make minor edits and then save them as PDF files. XnView does this very nicely except for the multi-page issue.
I have learned there's a work-around with Tools-Multipage file-Create, but it's very cumbersome for my purposes. So the program already has the ability to do what I want. It just needs to be a seamless part of Save As function.
Saving multiple page documents
Re: Saving multiple page documents
When saving multi page tiff, all pages are saved. Do you use the 1.96?
