filesize
mfeske
filesize
Post by mfeske »
Hello everybody,
I use this commandline:
%device%%nconvert% -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o %device%%tmp%wm\%%.jpg -high_res -ratio -rtype lanczos -rflag orient -wmfile "%device%%logoway%%logo%" -wmopacity 70 -wmflag top-left -wmpos %posx% %posy% %device%%in%%rotation%*.jpg
Why then is the file size smaller than before the conversion?
Before conversion 2638 KB, after 1021 KB ?
Is there a quality loss?
Greetings
Michael
Re: filesize
You can change the quality with -q xx
JPEG is not a lossless format
mfeske
Re: filesize
Post by mfeske »
xnview wrote:You can change the quality with -q xx
Hello Pierre,
but it is from jpg to jpg only with watermark ?!
Greetings
Micha
Re: filesize
mfeske wrote: but it is from jpg to jpg only with watermark ?!
Yes, but you load and save in jpeg, so there is a compress of picture data
