Import clipboard / commandline parameter
JohnFredC
Post by JohnFredC »
XnView Help says use the following to start XnView and import the clipboard:
{path to XnView}\XnView.exe -Clipaste
But silly me can't get it to work. What is the proper syntax?
Thanks!
John
Re: Import clipboard / commandline parameter
The clipaste parameter has to be all lowercase, I believe.
JohnFredC
Post by JohnFredC »
Thank you XnTriq... that worked.
I think I asked about this once before, but searched the forum unsuccessfully for it today.
John
