Hi there,
In my IPTC-box there are a left- and a right-arrow below the thumb, but they are somewhat deactivated, not usable.
Version is 1.95.4
Any idea I'd be grateful
How to jump to next image in IPTC-box?
marsh
Re: How to jump to next image in IPTC-box?
Do all the images support Iptc? With latest version, dialog is only visible when supported images are selected.
aki-108
well the dialog is showing up and working properly, only the arrows to previous and next images are in slight grey, deactivated.
marsh
Next to filename should be displayed: (file # / # of selected files). If it reads (1,4) and won't navigate the chosen ones, try newer v.1.96.2 in case there has been an improvement.aki-108 wrote:well the dialog is showing up and working properly, only the arrows to previous and next images are in slight grey, deactivated.
aki-108
ok it was my fault - didn't know one has to choose files first, but thought one could just proceed through the pictures in a folder without choosing;
thanks for support!
Aki
thanks for support!
Aki
