EXIF Thumbnails
xicex
EXIF Thumbnails
Post by xicex »
How do I view/edit/extract EXIF Thumbnails from JPEGs?
I only see rotate 90 and recreate..
But I can't view, or get it........
Re: EXIF Thumbnails
Currently no way, but perhaps it's a good thing to be able to extract jpeg thumbnail??
Hacker
Re: EXIF Thumbnails
Post by Hacker »
xnview wrote:Currently no way, but perhaps it's a good thing to be able to extract jpeg thumbnail??
Yes, since sometimes your picture gets damaged and the only image you can save is the thumbnail. :(
Roman
bucky
Re: EXIF Thumbnails
Post by bucky »
xicex wrote:How do I view/edit/extract EXIF Thumbnails from JPEGs?
I use exiv2 command line utility to view/set EXIF thumbnails. Not that user friendly, but if you must do this, then this is an option for now.
