Disabling F3 key?
bripriuk
Disabling F3 key?
Post by bripriuk »
Hi
Is there any way to disable the f3 (open with associated program) key? I don't use it, and I've just hit it by mistake instead of the f2 key and it tried to open 800 raw files in Photoshop. I know it's my own clumsiness, but its the second time I've done it and it means closing the computer (nothing else works).
Brian
Dreamer
Re: f3 key
Post by Dreamer »
Dreamer
bripriuk
Re: f3 key
Post by bripriuk »
Thanks for the info. I tried to get it to work but with no success - something I was doing wrong I think.
I've run out of time now, so I'll just have to be careful - thanks for your help anyway.
Brian
