XnView won't read some JPEGs
orion
Post by orion »
marsh
Re: XnView won't read some JPEGs
Post by marsh »
Both have error, "Premature end of JPEG file" according to other software.
Suggestion: Corrupt image indicator ?
obelisk
Post by obelisk »
I have some jpgs that read fine, but the thumbnails are rotated 90deg!
even when I open the file in PS and re-save, it's the same
Do you have tried to enable 'ignore read errors'?
marsh
Post by marsh »
obelisk wrote:I have some jpgs that read fine, but the thumbnails are rotated 90deg!
The embedded thumbnail can be recreated. This corrected a couple of offset 90° samples for me.
Menu>Edit>Metadata>Recreate EXIF thumbnail
