OSX NConvert PDF?
bandini
OSX NConvert PDF?
Post by bandini »
When I try to convert a one or many page pdf (to anything) I get the error...
./nconvert -out png 3.pdf
** NCONVERT v5.30 (c) 1991-2008 Pierre-E Gougelet (Feb 23 2009/18:27:16) **
        Version for MacOS X  (All rights reserved)
** This is a freeware software (for non commercial use)
sh: gs: command not found
  Error: Don't know how to read this picture (3.pdf)
re: Installation
I have nconvert and xnview.app in the same directory
Any ideas?
Thanks for your help.
Re: OSX NConvert PDF?
you must have ghostscript
bandini
Post by bandini »
That did it. Thank you.
abross86
Post by abross86 »
I'm having this same problem, however I can't figure out how to get ghostscript insalled correctly. I tried using the package I found here:
http://www.linuxfoundation.org/en/OpenP ... X/foomatic
..but after installing it I still get the same error. Any suggestions?
do you have the path of gs in your path var?
abross86
Post by abross86 »
I'm not sure. How would I check?
Btw, if I run the "gs" command in terminal, it runs ghostscript just fine.
abross86
Post by abross86 »
ok, so I found the gs binary and I put it in the same directory as nconvert, but now its throwing this error:
error "GPL Ghostscript 8.57: Unrecoverable error, exit code 1
Error: Don't know how to read this picture (/Users/aross/Pictures/scan1.pdf)
" number 254
You can't put only the exe, there is many other files used.
You should change your PATH env var
