[FIXED?] RC1: Transparency of Toolbar [OK]
Think the transparency of the new XnView default toolbar is not set properly. Instead of the XP grey the transparent areas are white.
Screenshot: http://www.sfp-online.de/xnview/web/1.8 ... arency.png
Can somebody confirm this?
icons transparence issue
Yes i do confirm this issue, i got the same here.
Also:
1 - XnView is not saving the layout configurations and reset the panels sizes when i launch it, panels like the view panel don't hold the size.
2 - the zoom keys + and - aren't working on fullscreen mode, in fact the Fullscreen itens on the settings panel aren't working too, they are ignored and you have to set the default zoon and etc with right click drop down menu on fullscreen, but if you restart XnView the settings gone and you have to set everything again.
3 - Getting scrollbars on fullscreen mode when the image is bigger that my screen (i like better when we could hide it)
4 - Also on fullscreen mode, i'm having a transparent boarder that show my desktop (it's very anoying).
Here a screenshot of some of this issues: http://img247.echo.cx/img247/9991/xnvie ... bug8qw.jpg
Holpe it can help you guys and that you for the great program
Also:
Re: RC1: Transparency of Toolbar
Yes, me too.helmut wrote:Think the transparency of the new XnView default toolbar is not set properly. Instead of the XP grey the transparent areas are white.
Ok, a little bug, please take xnview.manifest from old version 1.74.helmut wrote:Think the transparency of the new XnView default toolbar is not set properly. Instead of the XP grey the transparent areas are white.
Re: icons transparence issue
I can't reproduce the problem, which layout do you use?danilloOc wrote:1 - XnView is not saving the layout configurations and reset the panels sizes when i launch it, panels like the view panel don't hold the size.
Right a bug with +/-.2 - the zoom keys + and - aren't working on fullscreen mode, in fact the Fullscreen itens on the settings panel aren't working too, they are ignored and you have to set the default zoon and etc with right click drop down menu on fullscreen, but if you restart XnView the settings gone and you have to set everything again.
For me the fit setting of preview is saved
A bug3 - Getting scrollbars on fullscreen mode when the image is bigger that my screen (i like better when we could hide it)
It's strange, i'll check.4 - Also on fullscreen mode, i'm having a transparent boarder that show my desktop (it's very anoying).
Using the 3rd layout from the layout menu (3rd from top to botton)xnview wrote:danilloOc wrote:1 - XnView is not saving the layout configurations and reset the panels sizes when i launch it, panels like the view panel don't hold the size.
No, i can't reproduce this bug!!Anonymous wrote:xnview wrote:Using the 3rd layout from the layout menu (3rd from top to botton)danilloOc wrote:1 - XnView is not saving the layout configurations and reset the panels sizes when i launch it, panels like the view panel don't hold the size.
I want let you know that this will happen if you set XnView to go to full screen when double click the thumbnails.[/quote]4 - Also on fullscreen mode, i'm having a transparent boarder that show my desktop (it's very anoying).
