When I start XnView using xnview.sh, all I get is an empty window which I can drap, resize, close. But nothing than an empty window. I tried running it in a console window to check for any debug output, but all I get in there is:
ingo@ingo-laptop:~$ '/home/ingo/bin/XnViewMP/xnview.sh'
## MyTabWidget :: resizeEvent : 633 457
Funny thing is when I open an image via xnview.sh, I get the image display window and can then doubleclick in the image to view the main application window which looks totally okay.
That's the output in the console window:
Object::connect: No such slot AbstractViewWindow::onOpen()
##PB connect <1onOpen()>
Object::connect: No such slot AbstractViewWindow::onUndo()
##PB connect <1onUndo()>
Object::connect: No such slot AbstractViewWindow::onRedo()
##PB connect <1onRedo()>
Object::connect: No such slot AbstractViewWindow::onCut()
##PB connect <1onCut()>
Object::connect: No such slot AbstractViewWindow::onCopy()
##PB connect <1onCopy()>
Object::connect: No such slot AbstractViewWindow::onPaste()
##PB connect <1onPaste()>
Object::connect: No such slot AbstractViewWindow::onClear()
##PB connect <1onClear()>
Object::connect: No such slot AbstractViewWindow::onBackColor()
##PB connect <1onBackColor()>
Object::connect: No such slot AbstractViewWindow::onCrop()
##PB connect <1onCrop()>
Object::connect: No such slot AbstractViewWindow::onPagePrevious()
##PB connect <1onPagePrevious()>
Object::connect: No such slot AbstractViewWindow::onPageNext()
##PB connect <1onPageNext()>
Object::connect: No such slot AbstractViewWindow::onPageFirst()
##PB connect <1onPageFirst()>
Object::connect: No such slot AbstractViewWindow::onPageLast()
##PB connect <1onPageLast()>
Object::connect: No such slot AbstractViewWindow::onZoom(int)
##PB connect <1onZoom(int)>
Object::connect: No such slot AbstractViewWindow::onShowTabs()
##PB connect <1onShowTabs()>
==> 870e8c8 870e8c8
MENU install : 873c7c8
SLider : 0 0
SLider : 0 0
SLider : 0 0
SLider : 0 0
SLider : 0 0
SLider : 0 0
###### LOAD BITMAP </home/ingo/Pictures/desktop.JPG>
ViewWindow :: updateMenu()
SLider : 0 0
## OPEN FOLDER
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
setCurrentFilename </home/ingo/Pictures/desktop.JPG>
##onSelectionChanged </home/ingo/Pictures/desktop.JPG>
SLider : 0 0
### MyBitmapView :: resizeEvent 633 401
SLider : 0 0
## MyTabWidget :: resizeEvent : 633 436
SLider : 0 0
### MyBitmapView :: resizeEvent 633 356
SLider : 0 0
==> 633
SLider : 0 0
### MyBitmapView :: resizeEvent 633 380
SLider : 0 0
## MyTabWidget :: resizeEvent : 1024 768
SLider : 0 0
### MyBitmapView :: resizeEvent 1024 768
SLider : 0 0
## PaintEvent 1024 768 (8712668)
## PaintEvent 133 1 (8712668)
## PaintEvent 150 7 (8712668)
## PaintEvent 133 13 (8712668)
## PaintEvent 133 19 (8712668)
## PaintEvent 133 25 (8712668)
## PaintEvent 133 31 (8712668)
## PaintEvent 133 37 (8712668)
## PaintEvent 133 43 (8712668)
## PaintEvent 133 49 (8712668)
## xnview :: onShowFullscreen 0
SLider : 0 0
### MyBitmapView :: resizeEvent 1024 744
SLider : 0 0
## MyTabWidget :: resizeEvent : 1024 747
SLider : 0 0
### MyBitmapView :: resizeEvent 1024 723
SLider : 0 0
SLider : 0 0
### MyBitmapView :: resizeEvent 1024 689
SLider : 0 0
SLider : 0 0
### MyBitmapView :: resizeEvent 1024 667
SLider : 0 0
xnview :: onShowFullscreen ok
########### BrowserWindow :: BrowserWindow
Object::connect: No such slot BrowserWindow::onPagePrevious()
Object::connect: No such slot BrowserWindow::onPageNext()
Object::connect: No such slot BrowserWindow::onPageFirst()
Object::connect: No such slot BrowserWindow::onPageLast()
MENU install : 87ed960
Object::connect: No such signal BrowserWindow::updateMenuView()
Object::connect: (sender name: 'm_pPreview')
Object::connect: No such signal BrowserWindow::importClipboard()
Object::connect: No such slot MyView::setFit(int)
QWidget::setMinimumSize: (favoriteD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (categoryD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (keywordsD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (prevD/QDockWidget) Negative sizes (0,-1) are not possible
SLider : 0 0
SLider : 0 0
SLider : 0 0
########### BrowserWindow :: ok create (512 307)
BrowserWindow :: changeVisibility()
BrowserWindow :: updateMenu()
## checkChildren <Computer> 1
## checkChildren <Home> 1
########### BrowserWindow :: restoreState (1024 723)
#### onFavoriteDockVisible (1)
BookmarkNode::BookmarkNode : 88fa278
#### onCategoryDockVisible (1)
CategoryNode::CategoryNode : 8846f08 Rating
CategoryNode::add : 8846f08 to 87a2a40
CategoryNode::CategoryNode : 8843188 Excellent
CategoryNode::add : 8843188 to 8846f08
CategoryNode::CategoryNode : 8845a10 Good
CategoryNode::add : 8845a10 to 8846f08
CategoryNode::CategoryNode : 8831058 Average
CategoryNode::add : 8831058 to 8846f08
CategoryNode::CategoryNode : 8836d88 Below average
CategoryNode::add : 8836d88 to 8846f08
CategoryNode::CategoryNode : 8840d98 Bad
CategoryNode::add : 8840d98 to 8846f08
CategoryNode::CategoryNode : 8867158 Colour Label
CategoryNode::add : 8867158 to 87a2a40
CategoryNode::CategoryNode : 8845e28 Important
CategoryNode::add : 8845e28 to 8867158
CategoryNode::CategoryNode : 88506d0 Work
CategoryNode::add : 88506d0 to 8867158
CategoryNode::CategoryNode : 88fd228 Personal
CategoryNode::add : 88fd228 to 8867158
CategoryNode::CategoryNode : 88fd278 To do
CategoryNode::add : 88fd278 to 8867158
CategoryNode::CategoryNode : 88fd298 Later
CategoryNode::add : 88fd298 to 8867158
CategoryNode::CategoryNode : 88fd2f0
CategoryNode::add : 88fd2f0 to 87a2a40
CategoryNode::CategoryNode : 8902dc0 Categories
CategoryNode::add : 8902dc0 to 87a2a40
CategoryNode::CategoryNode : 8905108 Photographs
CategoryNode::add : 8905108 to 8902dc0
CategoryNode::CategoryNode : 8905180 Pictures
CategoryNode::add : 8905180 to 8902dc0
CategoryNode::CategoryNode : 89051a0 Icons
CategoryNode::add : 89051a0 to 8902dc0
CategoryNode::CategoryNode : 88fe890 Drawings
CategoryNode::add : 88fe890 to 8902dc0
CategoryNode::CategoryNode : 88fe8e0 Videos
CategoryNode::add : 88fe8e0 to 8902dc0
CategoryNode::CategoryNode : 88fe938 Audios
CategoryNode::add : 88fe938 to 8902dc0
CategoryNode::CategoryNode : 8903d38 Family
CategoryNode::add : 8903d38 to 8905108
CategoryNode::CategoryNode : 8903d58 Friends
CategoryNode::add : 8903d58 to 8905108
CategoryNode::CategoryNode : 8903dd0 Pets
CategoryNode::add : 8903dd0 to 8905108
CategoryNode::CategoryNode : 8903e20 Travel
CategoryNode::add : 8903e20 to 8905108
CategoryNode::CategoryNode : 88fee28 Landscapes
CategoryNode::add : 88fee28 to 8905108
CategoryNode::CategoryNode : 88fee80 Portraits
CategoryNode::add : 88fee80 to 8905108
CategoryNode::CategoryNode : 88fef10 Flowers
CategoryNode::add : 88fef10 to 8905108
CategoryNode::CategoryNode : 88fef30 Animals
CategoryNode::add : 88fef30 to 8905108
#### onKeywordDockVisible (1)
### BrowserWindow :: onStart
BrowserWindow :: onStart 2
setPathname </home/ingo/Pictures/>
## OPEN FOLDER
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
SLider : 0 0
LOADED from DB (554)
GFF :: LoadThumbnail : 0
LOADED & CREATED
IPTC GET Keywords <desktop.JPG>
QFileSystemWatcher: failed to add paths: /home/ingo/Pictures/
## checkChildren <bin> 1
## checkChildren <Desktop> 0
## checkChildren <Documents> 1
## checkChildren <downloads> 1
## checkChildren <Email signatures and PGP keys> 0
## checkChildren <kdenlive> 1
## checkChildren <mnt> 1
## checkChildren <Music> 1
## checkChildren <Projects> 0
## checkChildren <Public> 0
KeywordsThread :: run
KEYWORD : Get icon 0
KEYWORD : Get text 0
Any idea?
v0.12 Linux (Ubuntu 9.04): Empty window
ingoratsdorf
Re: v0.12 Linux (Ubuntu 9.04): Empty window
Any ideas? Anybody?
