All IPTC Data deleted after opening in Photoshop?
aki-108
Post by aki-108 »
Hi there,
1. had completed IPTC data of 800 pictures in XNVIEW
2. had opend half of them in Photoshop 7, made some corrections, closed
3. all IPTC data was gone.
does anyone know how that can be?
luckily had made a backup, but nasty nontheless
thanks
Re: All IPTC Data deleted after opening in Photoshop?
Your IPTC data was deleted by photoshop?? Do you reproduce this problem?
aki-108
Post by aki-108 »
I just copied two of the backup-files in Photoshop and saved them. As soon as I save them, the IPTC-data is gone; Should perhaps ask this in a Photoshop-Forum;
aki-108 wrote:I just copied two of the backup-files in Photoshop and saved them. As soon as I save them, the IPTC-data is gone; Should perhaps ask this in a Photoshop-Forum;
Yes
