I just noticed a very strange minor bug.
In "Capture screen", when set to "Active Window" or a specific window and "Include mouse cursor' is ON, the mouse cursor is drawn 4 pixels to the right of where it really was.
This does not happen when capturing the whole desktop, here the cursor is exactly where it should be.
At first I thought that there could be something wrong on my end since I'm using a custom windows skin, but it's OK when capturing the whole desktop, so there must be something else.
OS is Windows XP SP2
Screen capture with mouse cursor
Re: Screen capture with mouse cursor
Hmm, works without offset for me. I assume the problem occurs only with skin. Could you temporarily use standard window skin and see whether the problem still occurs?
Alpha-Toxic
I wonder why I did not try it with the default skin before.
So yes, it is working properly with the default skin. The problem only happens with the custom skin on maximized windows.
The skin is this one http://-kol.deviantart.com/art/aes-VS-31976742 , though I guess this is not really a bug in XnView.
Thank you for checking with default skin. Perhaps Pierre can try out with that special skin - not sure whether he finds time for this and can do something about it.
