ICC support
Discussions on XnView for PocketPC
xyz
ICC support
Post by xyz »
search image viewer with ICC support. What about this?
You can use this image for test.
Тhere is a way to build a monitor profile?
trids
Re: ICC support
Post by trids »
xyz wrote:search image viewer with ICC support.
:?: What does this mean? If we had this feature, what would it enable us to do?
Re: ICC support
trids wrote::?: What does this mean? If we had this feature, what would it enable us to do?
Embedded ICC profile honored (XnView v1.96.5):
Embedded ICC profile not honored (Internet Explorer 6 SP1):
xyz
Re: ICC support
Post by xyz »
Embedded ICC profile honored (XnView 1.96.5):
what about PDA version?
trids
Re: ICC support
Post by trids »
Thanks XnTriq!
Ok, so I loaded xyz's image onto my HTC Touch Pro2 (Rhodium) and viewed it with XnView, Opera, and HTC Album .. and they all displayed it incorrectly (dishonourably? :D ) .. which seems to suggest that the problem lies at a device/OS level? And I'm guessing this is why xyz is asking about building a monitor profile that XnView will honour in order to overcome this problem .. am I on the right track here?
