Fit window to image - only at startup?
fireslug
Post by fireslug »
Subject says it all. I've set Options/View/Auto Image Size to Fit window to image. Now if I open a small image first and then switch to a larger one, the window stays small. I'd like Xnview to automatically resize the window to fit every image (or at least enlarge the window when needed), not just the first one. Is this possible? If not, please add an option to "refit window for every image" to the feature request list!
Just out of curiosity, is the current behavior a bug or a feature?
marsh
Re: Fit window to image - only at startup?
Post by marsh »
This option may accomplish what you're looking for:
•Options>View>[x]Force XnView to fit image
fireslug
Post by fireslug »
marsh wrote:This option may accomplish what you're looking for:
Thanks, but I already have that option set and it still only works for the first image.
I can't reproduce, when i use 'Prev/Next File' the window is resized
lindtec
Post by lindtec »
Sorry to ressurect this old thread...
I have the same problem as the topic-starter.
My XnView is set up to fit the window-size to the image on default. Thist works like it should when I open an image-file.
But as soon as I go to the next picture, it keeps the window-size of the previous image.
I can go to "view">"auto-size">"Fit window to image" and it works again, but as soon as I restart XnView, I have the
same problem again.
Is there either a way to make the "general"-setting in the options-dialog work or to set "Fit window to image" as default
in the view-settings?
BTW. Im Using the newest XnView-Version (1.97.2) on a Windows 7 64bit OS.
lindtec
Post by lindtec »
angler2000 wrote:Very nice.
What do you mean with that? :?
marsh
Post by marsh »
It is a spammer. Most attempt to be conversational on forums these days.
lindtec
Post by lindtec »
marsh wrote:It is a spammer. Most attempt to be conversational on forums these days.
Damn. And here I thougt there was actually someone who migth be interested in my problem...
Oh well. Thanks, marsh, for clearing this up.
