very slow PNG writes
rra
Post by rra »
Recently I am using large 8-bit PNG files ,
crooping them and then saving back to PNG format.
The files are about 25 MB large on disk (unpacked 88 MB) .
Loading the PNG takes some 10 sec. , but when I save this file it takes 4 1/2 minute, with full (single core) processor load of a core-2 duo processor.
Curious as I am I did the same test with Photoshop CS4, loading goes with the same speed,
when I save the file in PNG format CS4 uses the 2 cores of my Core-2 duo processor fully,
but yet it takes a full 13 1/2 (!) minute to complete.
I am glad that XnVIEW is about 3 times as fast , but still it takes a very long time,
what is going on here ?? , and is there room for optimization ?
By the way: are there any processes (loading,saving,manipulating data, ... )
where XnView uses all cores of a multi-core processor, or is it only single core ?
René
EDIT: doing the same test with Paint Shop Pro (version 7.02) gives me an even faster write: 66 secs , that should be our target !!
eL_PuSHeR
Re: very slow PNG writes
Post by eL_PuSHeR »
Maybe Photoshop and the others programs aren't using maximum compression + preprocessing filters thus taking less time to complete.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
rra
Post by rra »
you are right, it had to do with the compression-factor,
in XnVIEW the compression can be set from 0 to 9;
I did a quick check with these 10 settings:
compr.; time (s) ; size (MB)
0 ; 38 ; 89.9
1 ; 19 ; 31.8
2 ; 20 ; 30.8
3 ; 22 ; 29.5
4 ; 23 ; 27.3
5 ; 28 ; 27.2
6 ; 46 ; 26.9
7 ; 65 ; 26.5
8 ; 230 ; 25.8
9 ; 270 ; 25.5
There is a big difference both in time and size, but for me a compression-setting of 4 would be good enough with a, acceptable file-size and compression-time
René
marsh
Post by marsh »
A related discussion:
PNG compression levels
rra wrote: where XnView uses all cores of a multi-core processor, or is it only single core ?
XnView use only 1 core
JohnFredC
Post by JohnFredC »
Ah...!!!
Now there is a reason for an XnView "2.0": multi-core!
8)
John
JohnFredC wrote: Now there is a reason for an XnView "2.0": multi-core!
After XnViewMP release, i'll work on multi core with XnViewMP (i've already made some tests)
rra
Post by rra »
Good news again Pierre,
will this MP version also support 64 bit ??
René
rra wrote:Good news again Pierre,
XnViewMP will have win, linux & mac 32 & 64bits version
