I want to increase the resolution when previewing pdf documents on a separate large monitor,
but I do not seem to find any parameter in the Options dialog allowing me to do this.
I am running 1.96.2 with Ghostscript 8.70
What should I do?
How to set preview resolution for viewing pdf files?
KrisR
Re: How to set preview resolution for viewing pdf files?
In Tools > Options | General > Read/Write | Read | EPS/PS/AI/PDF you can set the DPI. Default is 72 dpi, if you want to get a higher resolution, you increase the value (e.g. 300 dpi).
KrisR
Helmut,
Thanks a lot for the fast reply.
I just seem to have missed that menu.
