Resize using original compression settings?
Mangocrate
Post by Mangocrate »
I have a number of TIFF and PNG files that have a mix of compression settings depending on the content within them (some are zip/CCIT/jpg/etc).
I just need to resize all of them - but keep the original respective compression since it is best suited to the content of the image.
Is there anyway that I can tell nconvert to use the same compression as what the original file uses?
Re: Resize using original compression settings?
Mangocrate wrote:Is there anyway that I can tell nconvert to use the same compression as what the original file uses?
Not currently
