Hallo,
Is it possible to save the scroll position in the exif window from the preview pane?
If I would overfly exif tags from some pictures and the wanted tag is near the end from the exif list, I have the follow problem: If I select another picture, the scroll position is automatically set to the start of the exif list. And than I must scroll to the exif tag for every next picture, again and again.
My idea is therefore, to save the scroll position in the exif window between picture selection, especially if the picture from the same camera.
Maybe it would be also a good idea for the other lists in the preview pane.
Harry
Save scroll position in exif window...
Nutznieser
bucky
Re: Save scroll position in exif window...
That would be nice. Currently, I add the EXIF value that I want to the Show Information.
oops66
+1 good idea.
Dreamer
Good idea, but please check also this one - a bit more complex:
Custom Preview information pane tab & Properties tab
Dreamer
