increase length of Show Information field
bucky
Post by bucky »
I like to Show Information for all EXIF metadata, but I am running up against the length of the Show Information field. Could you make it longer (maybe 5x)?
Make: <Make>
Model: <Model>
Artist: <Artist>
Copyright: <Copyright>
Date Modified: <Date [Y-m-d H:M:S]>
Orientation: <Orientation>
Date taken: <Date Taken [Y-m-d H:M:S]>
Exposure time: <Exposure Time>
Exposure program: <Exposure Program>
Exposure mode: <Exposure Mode>
Exposure bias: <Exposure Bias>
Exposure index: <Exposure Index>
F-number: <F-Number>
Focal length: <Focal Length>
35mm focal length: <Focal Length 35mm>
ISO value: <ISO Value>
Shutter speed: <Shutter Speed>
Aperture: <Aperture>
Max aperture: <Max. Aperture>
Digital zoom: <Digital Zoom>
Subject distance (m): <Subject Distance>
Subj Dist Range: <Subj. Dist. Range>
Subject location: <Subject Location>
Flash: <Flash>
Flash energy: <Flash Energy>
Metering mode: <Metering Mode>
Gain control: <Gain Control>
Light source: <Light Source>
White balance: <White Balance>
Contrast: <Contrast>
Saturation: <Saturation>
Sharpness: <Sharpness>
Brightness: <Brightness>
Spectral sensitivity: <Spectral Sens.>
Spatial freq response: <Spatial Freq. response>
Sensing method: <Sensing method>
File source: <File Source>
CFA pattern: <CFA Pattern>
Custom rendered: <Custom Rendered>
Device settings desc: <Device Settings desc.>
Scene type: <Scene Type>
Scene capture type: <Scene Capture Type>
Image-ID: <Image-ID>
Image width: <Image Width>
Image height: <Image Height>
Image description: <Image Description>
Components conf: <Components Conf.>
Photometric int: <Photometric Int.>
Focal plane x-resolution: <Focal Plane X-Resolution>
Focal plane y-resolution: <Focal Plane Y-Resolution>
Focal plane res unit: <Focal Plane Res. Unit>
EXIF version: <EXIF Version>
White point: <White Point>
