Thumbnail not updated after altering picture
Adamsberg
Post by Adamsberg »
Hallo, everyone,
I need help for the following problem:
The browser thumbnails do not show alterations to the pictures. As a consequence i have e.g. three identical thumbs in the browser, which in reality ought to show three stages of modifications.
Re: thumbnails
:arrow: Adamsberg
:) Hello ! Welcome aboard !
• I assume that you are using “Embedded Thumb nail”, so they are not modified, only the main part of the picture is…
- Go to : Options (F12) Thumbnail (under Browser in the list) and untick the box
[ ] Use embedded Thumbnail >> [OK]
- It might do the trick …
:mrgreen: Kind regards
Adamsberg
Re: thumbnails
Post by Adamsberg »
Thanks for your tipp, unfortunately it did not help. Perhaps any other suggestions, please?
JohnFredC
Re: thumbnails
Post by JohnFredC »
Try this:
After following Clo's instructions...
Select the three thumbs, display right-click context menu, select "Rebuild thumbnails"
John
Adamsberg
Re: thumbnails
Post by Adamsberg »
Thanks a lot, it worked!
Nevertheless it is unsatisfactory.Many of the pictures I download, I use to slightly improve. That means a lot of wrong thumbnails which will not easy selections.
Isn't there a means of basically sttling this matter?
Further tipps will be appreciated.
